Forums >> General Discussion >> Wishlist >> Tension Cable
Thu, Oct 20, 2005 at 12:01:45 PM | Tension Cable
lwasden
Im looking for some sort of tension cable that I can run from a cantilevered deck to the plate in the wall. Anybody have any suggestions on how to do this? Even if it is actually a column, if there's a way to make it placed at an angle.Smile
Sat, May 26, 2012 at 6:11:14 PM | Tension Cable
ndunning
me too!!!!
Sat, May 26, 2012 at 6:12:42 PM | Tension Cable
ndunning
Oh and you can place slanted columns, it is under the placement options of the column. Has anyone gat a nice steel tensiontie though:? Or any ideas on how to render the twist of the different strands in the cable?
Sun, May 27, 2012 at 5:49:34 AM | Tension Cable
4 Stars: 205 Votes
Like what? images please...
Sun, May 27, 2012 at 6:54:39 AM | Tension Cable
Modify the family in this thread as needed.
http://revitcity.com/forums.php?action=viewthread&thread_id=25324
Tension Structure/Membrane
Sun, Nov 6, 2011 at 7:50:07 AM
tension membrane structures in Revit
Sat, Feb 4, 2012 at 6:19:59 AM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
Cable Tray Clearance
Mon, Mar 24, 2014 at 10:44:48 AM
Page generation time: 0.1071
