Forums >> Revit Building >> Technical Support >> can't render background image at 300DPI
Tue, Oct 5, 2010 at 7:05:18 AM | can't render background image at 300DPI
HuibersJarring
when i render at 150 DPI i can see my background image, but when rendering at 300 DPI my background image turns black.
How can we make this work ?
Tue, Oct 5, 2010 at 7:29:09 AM | can't render background image at 300DPI
4 Stars: 205 Votes
wierd... what version are you working on?
Tue, Oct 5, 2010 at 9:34:20 AM | can't render background image at 300DPI
HuibersJarring
Revit 2011 architectural
Tue, Oct 5, 2010 at 9:46:24 AM | can't render background image at 300DPI
4 Stars: 205 Votes
Did you install the two (2) "Web Updates" for 2011?
Wed, Oct 6, 2010 at 1:07:56 AM | can't render background image at 300DPI
HuibersJarring
we installed 2 updates so far.
the last one was last week.
I think the problem is the memory.
the same rendering at 300DPI worked on my laptop but didn't at work.
The computer at work has a 3gB switch, but still isn't enough i guess..
Wed, Oct 6, 2010 at 1:27:39 AM | can't render background image at 300DPI
gebber
gebber Avatar
5 Stars: 4 Votes
"at 300DPI worked on my laptop but didn't at work."
Are you sure it can find the path for the image?
If it would be a memory problem I think the back ground would not be the hardest to calculate it's just an image to load.
Wed, Oct 6, 2010 at 1:58:32 AM | can't render background image at 300DPI
HuibersJarring
I'm sure it finds the path.
It works fine at 150 DPI, but turns black at 300 DPI..
Mon, Oct 11, 2010 at 11:26:56 AM | can't render background image at 300DPI
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Have you tried adjusting the crop size? That may help if you make the image your rendering smaller.
J. Allen Ball
Revit Architecture 2010 Certified Professional
HOW TO RENDER TO 300DPI and to save an UNCOMPRESSED FILE?
Thu, Apr 28, 2011 at 6:27:19 PM
IMPORT BACKGROUND IMAGE TO RENDER IN RAC2009?
Tue, May 6, 2008 at 12:25:34 AM
show background image in render window?
Fri, Aug 13, 2010 at 2:56:56 PM
Rendering-Background Image-I don't find that option in Mental Ray
Fri, Jun 20, 2008 at 10:42:00 AM
Ground Plane / Background image
Tue, Jun 21, 2005 at 6:20:03 PM
Page generation time: 0.5676
