Forums >> Revit Building >> Technical Support >> Roof Hatch Not Visible
Mon, Oct 4, 2010 at 2:29:25 PM | Roof Hatch Not Visible
rachelbarnes
In my roof plan view, the standing seam metal roof hatch is not showing up. The hatch is part of the roof structure, it is a modeling hatch that is just vertical lines spaced 12" apart. It shows up in a 3D view correctly, and all roof check boxes in VG are on. I can't figure it out. Usually I want to turn off a roof hatch in the roof plan view, and I would do that in the override graphics dialog box. The check box next to "visible" under surface patterns is on, so I don't know why I'm not seeing it. Please help! And thank you in advance.
Mon, Oct 4, 2010 at 3:54:45 PM | Roof Hatch Not Visible
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Turning anything off "by element" is never good practice.  To turn off all roof hatches use the visibility/graphics dialog and in the surface pattern column of roofs click and uncheck "visible" here.  This then applies to all roofs in the view.
If you require to apply to only some roofs then use filters and then control the visibility of the filter.  This way this could be included as part of a view template and essentially be a 2 click process to setup your roof plans.
But if you have hidden by element, select your roof, goto override by element, and then recheck visible.  If not, then most likely its been hidden using the visibility/graphics.
If that isn't it, it could be a phase filter overriding the material...
HTH.
Regards,
Chris.
Sat, May 30, 2015 at 10:34:24 PM | Roof Hatch Not Visible
aaronmayer
This is also something that I prefe to do, Hopefully I could get much idea from here try it for myself.
http://caldwells.com/interior-doors/glass-doors
cant see roof hatch in elevation
Mon, Sep 10, 2012 at 10:50:14 AM
Roof Hatch?
Mon, Feb 26, 2007 at 1:15:22 AM
How to get roof hatch to match roof fall
Thu, Sep 22, 2005 at 3:23:09 AM
Why Roof Cutplanes are visible in RAC 2008 and Why not in Revit Building 9
Wed, Jul 16, 2008 at 10:34:18 AM
Colums Hatch
Mon, Dec 2, 2013 at 8:07:35 AM
Page generation time: 3.4183
