Forums >> Revit Building >> Technical Support >> Column Line grids disappear - revit building 2009
Mon, Oct 4, 2010 at 1:05:28 PM | Column Line grids disappear - revit building 2009
joeinck
got a strange one here...
for some reason, half my column lines dont show up in all my views except one, a roof plan. they where working fine, I had 7 column lines and when i added 6 more, those 6 show up but not the first 7? Crazy, i have attached an image if anyone has a guess as to what is going on
Mon, Oct 4, 2010 at 1:32:51 PM | Column Line grids disappear - revit building 2009
Col grids and floor levels have limits, they are not infinet in location.  When they show in one view and don't show in another, that is because you have to extended them into that view range.  In elevations, when you click on one of these elements, you will see either a 2D or a 3D near the end of the reference line.  2D adjustments of these lines are that view only, 3D will adjust the limits for all views.
Read this in your HELP:> Maximizing 3D Model Extents
Mon, Oct 4, 2010 at 4:09:46 PM | Column Line grids disappear - revit building 2009
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes, I would definintely recommend using Scope Boxes to control all your datum extents.  Greatly simplifies the management of this.
Regards,
Chris.
columns grids not recognized
Wed, Oct 6, 2010 at 9:55:29 PM
Revit Architecture 2012 - Column Grids not Parallel to View will not show up
Wed, Nov 23, 2011 at 1:27:06 PM
Column Grid Question in Revit 2008
Sat, Apr 26, 2008 at 4:56:38 PM
Topo hatch disappear under building pad
Mon, Jan 27, 2014 at 8:27:53 AM
Grids
Thu, Dec 15, 2011 at 2:01:34 PM
Page generation time: 4.7651
