19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> structural column family
6 Posts No Rating |
Hi,
is it possible to take the beam library and create a column library. I need to do angle as column or leg. I tried to copy the angle beam library to column library without good result. what can be done
thanks
They are already in the Revit [ Imperial Library-Structural-Columns-Steel ] folder.
"EDIT" - Sorry I didn't read your question well enough, no "L" shaped there.
Post edited on 2005-10-20 16:05:18
I toyed with this a bit - Try Loading these into your structural Column Families
Looks like I can only load one at a time.
This is the family
EDIT - had to make some changes. Get it from second post
Post edited on 2005-10-20 17:02:46
This is the library
Edited .rfa file
The L-Angle has two profiles, this family version gives the option of selecting which profile.
EDIT: I see the files are uploading and assigning numbers to the succesive files. Be sure and name the family and library files the same and install both in the same folder.
Post edited on 2005-10-21 13:44:50
6 Posts No Rating |
thanks Rythmick I will try and let you know
structural column member not selectable |
Wed, Jul 19, 2006 at 9:26:06 AM
Visibility graphics of a structural column |
Mon, Aug 16, 2010 at 8:21:00 AM
Constraining Structural Column Within a Revit Family |
Fri, May 9, 2008 at 3:22:04 AM
Structural Column not working |
Mon, Jul 2, 2018 at 10:20:09 AM
Column in shoring pile family disappears when it intersects geometry |
Mon, Aug 9, 2010 at 1:04:48 PM
