Forums >> Revit Building >> Technical Support >> Profiles on a meandering sweep.
Mon, Oct 4, 2010 at 12:38:44 PM | Profiles on a meandering sweep.
ACovenantor
Is it possible to create a profile on a meandering sweep as displayed on this early 1900's Neo-Baroque school auditorium:
Mon, Oct 4, 2010 at 2:00:03 PM | Profiles on a meandering sweep.
lunchtrayrider
3.5 Stars: 7 Votes
yes. what have you tried so far?
Mon, Oct 4, 2010 at 2:42:25 PM | Profiles on a meandering sweep.
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
You can pick a 3D edge (or a chain of them) for the path of your sweep.
I have a rendering underway so I can't test this, and I'm not an expert in fancy trim--but if you can't use a wall's edited profile for your path, you can model the facade quickly in the same family as the sweep for a foolproof solution.  In that situation I know you can use pick 3d edge.
Mon, Oct 4, 2010 at 3:42:01 PM | Profiles on a meandering sweep.
itsmyalterego
4 Stars: 16 Votes
edited wall profiles *are* acceptable 3d edges.  Here's an example.
Tue, Oct 5, 2010 at 12:40:36 PM | Profiles on a meandering sweep.
ACovenantor
How are you able to make the sweep follow a 3D path?
Wed, Oct 6, 2010 at 12:58:17 PM | Profiles on a meandering sweep.
ACovenantor
Never mind, a few hours after theat post a friend of mine figured out the way of creating a 3D path.
 Thanks for the help!
Thu, Jan 27, 2011 at 10:38:17 AM | Profiles on a meandering sweep.
Chaffeystudent
wat is the process or steps to creating a meandering sweep?
Thu, Jan 27, 2011 at 12:50:57 PM | Profiles on a meandering sweep.
itsmyalterego
4 Stars: 16 Votes
Here's a related thread I posted in a bit ago.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=22616
To recap, When you model a family in place, pick a sweep.  Instead of selecting "sketch path" to start your sweep, you can use "pick path."  By default, you'll now be using the "pick 3D edges" tool, so, just start picking your path along a chain of 3d edges and you're good to go.  After you sketch the profile like usual.
Edited on: Thu, Jan 27, 2011 at 12:52:01 PM
Sweep Profiles in Version 9
Thu, Aug 3, 2006 at 2:14:05 AM
Multiple Profiles in a Sweep
Fri, Nov 2, 2007 at 6:02:35 PM
Blend sweep problem
Tue, Feb 28, 2012 at 1:51:35 PM
Multi-profile Sweep
Fri, Jan 22, 2010 at 8:08:14 AM
loading profiles
Sat, Feb 18, 2012 at 3:43:54 AM
Page generation time: 0.0939
