Forums >> Revit Structure >> Technical Support >> Footings not showing up correctly
Mon, Oct 4, 2010 at 8:52:37 AM | Footings not showing up correctly
davidlowery
RST 2011
Where a continuous footing meets with an isolated pad, the lines kind of overlap.  All the elevations are correct and I have done join geometry, which didn't do anything.  I want the footing lines to be continuous.  How can I make this happen?
Mon, Oct 4, 2010 at 8:58:26 AM | Footings not showing up correctly
TKennedy
4 Stars: 8 Votes
It's been a while since I've made any footings, but here is what I can remember: Top of footing has to be exactly the same. Sometimes you have to use join geometry (sounds like you've done both of those) and if I recall correctly, the material needs to be the same.
Tue, Oct 5, 2010 at 1:03:31 PM | Footings not showing up correctly
mholzer
4 Stars: 1 Votes
davidlowery,  I think you are seeing lines where the continuous footing meets the isolated pad because the thickness of the isolated pad is greater than the thickness of the continuous footing.  When the thickness of the isolated and continous footings are the same the lines to not show up where the two meet.
isolated footings not showing up
Wed, Jul 18, 2012 at 1:17:11 PM
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Auto Footings
Tue, Apr 4, 2006 at 10:10:15 PM
Footings, getting double hidden lines and intersections suck!
Fri, Aug 31, 2012 at 10:13:08 AM
toposurface adjusts to linked model footings
Sat, Oct 22, 2011 at 10:11:33 AM
Page generation time: 0.6681
