Forums >> Revit Building >> Technical Support >> Door swings
Thu, Oct 20, 2005 at 9:54:35 AM | Door swings
nextvkin
Hello, I've come across tutorials showing how to create door families with different degrees of door openings, but only in plan view and I believe using symbolic lines. Is it possible to do this with extruded elements so that it's visible in 3D view?
Thu, Oct 20, 2005 at 10:31:03 AM | RE: Door swings
Rythmick
5 Stars: 2 Votes
Yes, when you make the door family you need to create a door swing parameter (dimension) that controls the angle of the door extrusion. A way to do that would be to use a reference line that is controlled by the swing parameter and use that as the working plane for the door extrusion.
Thu, Oct 20, 2005 at 7:20:17 PM | RE: Door swings
nextvkin
Thanks Rhythmick, I did try doing that (unsuccessfully) but from reading your answer I think I know where I went wrong ; I'll givitago.
Fri, Oct 21, 2005 at 5:07:48 AM | RE: Door swings
dexter303
Has anybody done this? A basic door that swings in 3D? Help needed..
Fri, Oct 21, 2005 at 8:59:05 AM | RE: Door swings
Rythmick
5 Stars: 2 Votes
Here it is with the door template and a basic slab door.
Fri, Oct 21, 2005 at 9:00:48 AM | RE: Door swings
Rythmick
5 Stars: 2 Votes
Oops hit the wrong button -
Door swings in RCP
Thu, Jul 18, 2019 at 5:03:06 PM
creating double door with multiple swings
Fri, Oct 31, 2014 at 1:44:28 PM
Hide door swings which are visible from floor below
Wed, May 6, 2015 at 12:16:03 PM
DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011 [ 1 2 ]
Sun, Jan 13, 2013 at 11:26:10 AM
29
Door swings in 3d view
Tue, Dec 1, 2009 at 7:41:35 AM
Page generation time: 0.5028
