Forums >> Revit Building >> Technical Support >> Custom elevation tag
Fri, Oct 1, 2010 at 2:27:19 PM | Custom elevation tag
SteveB
3.5 Stars: 5 Votes
in r2011 one can create a "custom elevation tag".
C:\Program Files\Autodesk\Revit Architecture 2011\Program\Help\en-US\WBH\filesUsersGuide\WS73099cc142f487551d68dd061249d36330f-6cf7.htm
rather than "do it yourself" is this tag available for download?
Sat, Oct 2, 2010 at 8:51:17 PM | Custom elevation tag
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
take one that already works, and then edit it for what you need. ( metric library is in
C:\Documents and Settings\All Users\Application Data\Autodesk\RAC 2011 )
Sun, Oct 3, 2010 at 7:35:54 AM | Custom elevation tag
SteveB
3.5 Stars: 5 Votes
Its already in the r2011 annotation symblos:
you load the elevation mark family into the drawing via insert/load family/Elevation Mark Body_Custom.rfa
you now select it as the one to use as follows:
  1. Click Manage tab/ Project Settings panel/ Settings drop-down/Callout Tags, Elevation Tags, or Section Tags.
  2. In the Type Properties dialog, edit type properties as necessary.
spot elevation & custom pipe tag
Mon, Mar 24, 2014 at 10:29:52 AM
Custom Elevation Symbol is upside down sometimes
Tue, Apr 12, 2011 at 11:10:28 AM
Changing the size of the interior elevation tag
Wed, Dec 20, 2006 at 12:26:41 PM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Incorporating a Spot elevation tag into a custom made pipe "size" tag
Fri, Dec 13, 2013 at 8:28:38 AM
Page generation time: 1.2973
