Forums >> Revit Systems >> Technical Support >> render interior spaces
Thu, Sep 30, 2010 at 2:27:46 PM | render interior spaces
lightshadows23
I tried to show 3d interior spaces on a project I'm doing and it doesnt even show :S I just zoom on exterior wall and it gets to a point where its all grey. I did the vg and then show room but still doesnt work..I don't know if there is other way as before I was using sketchup and it was kind of easier just walk through walls.
please if there is other way to do it ,someone let me know cause Im new to revit Smile
Thu, Sep 30, 2010 at 5:50:30 PM | render interior spaces
gebber
gebber Avatar
5 Stars: 4 Votes
There can be many problems with this discription.
Does the image show when you haven't renderd
Have you set the render ar interior lights?
Have you created interior lights.
Are you sure you're not waching against or inside a wall
Are you sure you have set the materials (when using imported sketchup components you'll have to reassign the materials.
Even when everything is set as it should, rendering interior scenes in revit still is a curse (excuse my french) it can take days.
Fri, Oct 1, 2010 at 9:04:58 AM | render interior spaces
lightshadows23
Im talking about before rendering.i cant even see just by seeing the interior space in 3D speaking.(I can see interior on section.)
I dont think Im seeing through wall cause I zoomed alot of times and its still doesnt show:S
Im sorry to hear that revit is hell for interior renders but for now outside spaces are done quite fast..
 is there a specific button I have to choose to see inside space or I just have to walk through spaces?
Fri, Oct 1, 2010 at 9:14:22 AM | render interior spaces
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
You said "I just zoom on exterior wall and it gets to a point where its all grey" - what does this mean? You need to use "camera" to create views.... try that and see what happens.
 "If you tell the truth, you don't have to remember anything"
Fri, Oct 1, 2010 at 9:15:40 AM | render interior spaces
gebber
gebber Avatar
5 Stars: 4 Votes
Have you tried to make an new camera view?
Have you tried to set the view on wireframe?
Fri, Oct 1, 2010 at 9:43:03 AM | render interior spaces
lightshadows23
aa yeah I forgot about that!thank you
but now I have other problem because the spaces look gigantic(any way to make them on scale?) and when its far It gets to a point where its all white again sometimes :S
Fri, Oct 1, 2010 at 9:52:46 AM | render interior spaces
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
In plan view, show camera.... and then adjust the depth of FOV by dragging.
Fri, Oct 1, 2010 at 12:06:27 PM | render interior spaces
lightshadows23
now it seems its working finePuh
thank you all alot for ur help!
Fri, Oct 1, 2010 at 3:53:24 PM | render interior spaces
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
If your renders are entirely black in interior views, it's likely an exposure problem or a lack of interior lights.  It's also possible that your render library is missing and/or everything is set to black.
The exposure slider is -very- touchy, but can make all the difference in your rendering.  Remember that these settings are changed post render, so, sometimes you have to render something too dark to see, and have faith it'll look good with some adjustment.  Or, test it out as a draft render, get your settings correct, and then render at a higher quality.
Render exterior view with artificial lights - how to make interior glow?
Sun, Mar 11, 2012 at 12:45:28 PM
Revit Spaces Elec VS Mech
Tue, Feb 2, 2010 at 10:50:50 AM
Spaces don't recognize exterior walls
Fri, Feb 3, 2012 at 9:49:40 AM
Exterior Render-Interior too dark!!
Tue, May 4, 2010 at 7:31:50 AM
Revit render interior settings?
Sun, Feb 10, 2013 at 10:13:59 AM
Page generation time: 1.1066
