Forums >> Revit Building >> Technical Support >> Filled Region Border Visibility
Thu, Sep 30, 2010 at 8:33:09 AM | Filled Region Border Visibility
mpkarch
I am working with Revit Building 9 and would like to use a filled region as a masking region in my wall sections.  I have changed the fill properties to white and opaque but I don't seem to see how I can make the border line white or invisible.  Does anyone have any suggestions?
Thu, Sep 30, 2010 at 8:59:34 AM | Filled Region Border Visibility
Use an invisible line when you create it.  Or edit the region and change the lines to invisible.
Thu, Sep 30, 2010 at 9:43:14 AM | Filled Region Border Visibility
mpkarch
Thank you.  I will try that.
Visibility of Filled Region Boundaries over walls
Wed, May 24, 2017 at 1:54:59 PM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
Filled Region Object Styles
Mon, Dec 21, 2009 at 11:12:11 AM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Revit filled regions
Mon, May 5, 2008 at 7:09:26 AM
Page generation time: 0.3098
