Forums >> General Discussion >> Revit ROI >> Inserted Image prints upside down
Wed, Sep 29, 2010 at 11:00:16 AM | Inserted Image prints upside down
bodiky
Hello everyone!
I have been working in Revit for several years and know this program very well.  However, I have just started with a new company and I believe there might be a printer issue, but I want to see if anyone else has had this issue before to see if I can fix it myself in Revit.  I've never had this problem before.
I am using Revit 2011 and whenever I print an image whcih has been inserted or print a rendering from the file, it prints on the sheet upside down.  For instance, I am using a 11x17 sheet and I have just dragged over my rendering onto the sheet.  It prints upside down.  Or if I inset an image from a file onto the sheet, it still prints upside down.
 I tried rotating the image, hoping that for some unknown reason it would print right-side up, but the image just then disappeared!
Any ideas?  Has this happened to anyone else?  I have tried printing to another printer, and there were no issues.  However, this is the only printer that we have that's 11x17 capable, therefore I really need this printer to work.
 Let me know if anyone has any ideas!  Much appreciated!  - Kylie
Wed, Sep 29, 2010 at 11:07:34 AM | Inserted Image prints upside down
Try printing to PDF.. If it prints correctly there, then it is probably a print driver issue.
Wed, Sep 29, 2010 at 12:53:45 PM | Inserted Image prints upside down
jackhoward
My company has the same issue, only on 11x17, and we print to pdf, then print the pdf on 11x17 and it works.  It's an extra step yes, but we print to pdf for recording anyways.
Sun, Nov 13, 2016 at 9:42:45 PM | Inserted Image prints upside down
pmartini2012
Interestingly enough, I just started having this issue.  I have a few sheets of general notes which are just documents from the city that need to be in every set of drawings.  I have a few drafting views with 11x17 .jpg's, and only one of the drafting views with these .jpg images prints them all mirrored.  I have been printing directly to PDF because I need to send them over to a client.  I had been using the Foxit PDF printer driver.  I then switched to the Cute PDF printer (another straight-to-PDF printer driver), and the problem went away.
Inserted image appears with line on one edge (2013)
Thu, May 9, 2013 at 3:55:56 PM
Inserted Image not visible
Fri, May 15, 2009 at 10:26:13 AM
Can't Zoom into Inserted Image
Thu, Jul 1, 2010 at 5:06:11 AM
Locking inserted image/dwg file
Mon, Aug 29, 2011 at 9:38:25 AM
How to embed an image into a titleblock?
Tue, Jan 25, 2011 at 11:22:19 AM
Page generation time: 0.2926
