Forums >> Revit Building >> Technical Support >> System Panel Door
Wed, Sep 29, 2010 at 9:55:55 AM | System Panel Door
mbkarp
I have not been able to create or find a good system panel curtain wall door.
 I have made a door that works as a model by using a kawneer 350 door and building a frame around it that works reasonably well in plan, elevation, and details.  Beyond the door not adjusting hieght without force the main issue I have with the door is that it does not measure correctly in the door schedule.  The door schedule seems to measure the door width from inside face of mullion to inside face of mullion which means it counts the door frame in the door size.  Is there a way that I can exclude the door frame from the measurement?  Does anyone know of a curtain wall door manufacturer who has a good system panel door + frame?
 Using Revit Arch 2011
Thanks in advance,
Matt
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
Phasing for storefront system panel
Wed, May 18, 2011 at 7:44:36 AM
customerized curtain panel doesn't work with the irreglar shaped panel?
Sat, Jul 10, 2010 at 1:48:42 PM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
missing empty curtain wall system panel
Thu, Aug 4, 2016 at 7:17:33 AM
Page generation time: 0.8733
