Forums >> Revit Building >> Technical Support >> Move detail component with nearby elements
Wed, Oct 19, 2005 at 9:01:23 PM | Move detail component with nearby elements
antfa
Is it possible to have detail componets move with nearby elements?
Wed, Oct 19, 2005 at 11:17:52 PM | RE: Move detail component with nearby elements
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes detail components can be locked to elements as required
Wed, Oct 19, 2005 at 11:44:10 PM | RE: Move detail component with nearby elements
Scott Davis
3.5 Stars: 3 Votes
You can also group a set of detail components, then lock the group to nearby elements. Sometimes this is easier than locking the indiviudual components.
Thu, Oct 20, 2005 at 1:45:05 AM | RE: Move detail component with nearby elements
antfa
Hi thanks for your comments, so how do i lock a group to nearby components? i can't seem to find the option? Thanks Antfa
Thu, Oct 20, 2005 at 12:13:14 PM | RE: Move detail component with nearby elements
Scott Davis
3.5 Stars: 3 Votes
Once you create the group, use Align to align the group to some other geometry, then the Lock symbol will appear. Lock the relationship by clciking the lock.
Thu, Oct 20, 2005 at 2:51:10 PM | RE: Move detail component with nearby elements
antfa
Brilliant! Thanks I've been exploring revit structural for a few weeks now, and every day it blows me away.
Pin Detail elements to move with Nearby Walls etc
Fri, Aug 13, 2010 at 7:12:19 PM
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Can't move component vertically
Fri, Apr 20, 2018 at 3:22:19 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
Revit 2023 - Line-based Detail Component with mask
Thu, Nov 9, 2023 at 5:57:04 PM
Page generation time: 2.2162
