Forums >> Revit Building >> Technical Support >> Building Pad
Tue, Sep 28, 2010 at 11:50:09 PM | Building Pad
Rgoldie13
When placing a building Pad in a Topo. How do I show a batter or angle on the cut/fill?
Wed, Sep 29, 2010 at 7:06:51 AM | Building Pad
Pad is different than cut and fill.  If you meant how to slope your pad, their is a slope arrow you can add when you create the pad.
Thu, Sep 30, 2010 at 12:18:13 AM | Building Pad
Rgoldie13
Thanks for your response, no, I didn't mean "slope" or "grade" on the pad surface, I mean the sides of the pad, they are "cut" vertical in the topo, Can they be sloped out 45 deg.
 If "Cut/Fill is different, perhaps that's where I'm going astray, how do I create a cut/fill bench oe building pad in the Topo?
Thu, Sep 30, 2010 at 7:17:11 AM | Building Pad
Pads are meant to provide a finished cut for your building only - not an excavation cut.  If you want that, you would have to probably use cut and fill.  This would not be easy and my question is why would you want to.
Thu, Sep 30, 2010 at 11:41:28 AM | Building Pad
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Site development in Revit is very difficult now. You must use the cut and fill tools which are tricky. I have done some hillside work with them, not impossible but difficult. Also street work is tricky. See attached for a method there are others that will work.
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:08 PM
Building Pad Altering My Topography Surface
Wed, Nov 30, 2011 at 12:01:59 PM
Building Pad and Ecotect
Wed, Feb 2, 2011 at 11:12:06 AM
building pad
Wed, Dec 2, 2009 at 8:34:09 AM
Building pad, what is it exactly?
Mon, Dec 20, 2010 at 11:51:40 AM
14
Page generation time: 0.8537
