13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Railing
4 Posts No Rating |
How do I create a criss/cross Railing. Old Queenslander style.
Find a railing that has a decent base point of what you are after. Maybe a few balusters and top and bottom rail. Then you will need to edit the railing properties. Pretty easy to do. Just play around with the settings and you may need to edit the baluster families and railing families to get the look you are after. You can really do some great things with railings. You can build an entire stair by using a railing.
Search in Net for "Insanely Great Stairs and Railings with Autodesk® Revit® - Phil Read – HNTB Companies"
4 Posts No Rating |
Thanks for the response, I started by duplicating an existing family and have midified it to the extent of removal of existing posts and balusters retaining only the rails. I need to insert a post at centre span and the balusters need to be raked to form an X shape. See PDF attached. Thanks
Railing not shown in list |
Mon, Jun 30, 2014 at 4:25:56 PM
rectangular railing |
Mon, Nov 26, 2012 at 7:30:07 AM
Railing Turns Into Transparent Red |
Thu, Aug 10, 2017 at 2:06:41 AM
Railing and Baluster Profiles not inserting on centerline? |
Fri, Oct 5, 2012 at 2:26:20 PM
Newbie help: how to intersect railing with baluster |
Wed, Mar 25, 2009 at 4:26:53 AM
