Forums >> Revit Building >> Technical Support >> How do I angle a wall
Tue, Sep 28, 2010 at 1:55:09 PM | How do I angle a wall
lavendi321
4 Stars: 16 Votes
I need to angle a wall in a 2 story model I am doing. is there anyway to do this, and laso place a window in that wall that is aligned with the angled wall?
 Thanks
Tue, Sep 28, 2010 at 1:59:56 PM | How do I angle a wall
4 Stars: 205 Votes
Images please.....
Tue, Sep 28, 2010 at 2:03:00 PM | How do I angle a wall
RevitCafe
RevitCafe Avatar
In the x and y direction, you can rotate the wall easily. In the Z direction you can use other options, but no, revit doesn't allow that (not that I know of). You can make a wall from in the project using masses. These are not parametric, and probably aren't to good of an idea. You can also create a mass and host the wall on it. The windows and doors do not look good like this.
Cheers,
Craig Hanus
Revit Cafe
www.revitcafe.com
Please visit me at Revit Cafe www.revitcafe.com
Tue, Sep 28, 2010 at 2:28:42 PM | How do I angle a wall
lavendi321
4 Stars: 16 Votes
can i associae a curtainwall to a mass, i am using revit 2009. i have a sloped wall, and want to insert a storefront wall into this sloped wall i have associated to a mass
Tue, Sep 28, 2010 at 10:07:49 PM | How do I angle a wall
RevitCafe
RevitCafe Avatar
Yes you can. A curtainwall, or Storefront in this case is a wall. Simply change the type from wall 'x' to curtainwall 'y'.
Cheers,
Revit Cafe
www.revitcafe.com
Curtain wall to wall at an angle
Tue, Jun 12, 2018 at 2:38:49 PM
Wall based embeded angle not keeping hd stud in place.
Tue, Apr 5, 2016 at 2:49:55 PM
Angle curtain wall
Thu, Jan 24, 2013 at 3:00:57 PM
Chairail on an angle
Wed, Jun 22, 2011 at 3:29:35 PM
3D in place sweep problem, changes angle
Mon, Jan 28, 2008 at 12:56:37 PM
Page generation time: 0.5580
