17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Importing Walls
20 Posts No Rating |
Hi all This is probably a real basic question, with simple answer ... but I'm stuck. I opened a Revit 2010 file in my brand new Revit 2011. It only imported the components and families that I was using in the 2010 version. I need to add a wall thats not in the wall drop-down menu. How do I do this? I can't see anything in the library ...
You can create a new wall type from a wall that is already in the project or if you have walls defined in other projects and with both projects open in the same Revit session, you can copy to clipboard and paste into your current model.
Thanks WW Seems a bit convuluted, but will give it a go. Wonder why Autodesk haven't come up with a simpler solution?
Converting Room Areas to Walls and Importing ADT lines into Walls |
Mon, Sep 15, 2008 at 12:44:51 PM
Importing walls into an Rfa file |
Tue, Jun 13, 2017 at 6:12:03 AM
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES |
Sun, Sep 24, 2006 at 10:37:21 PM
Problems when importing Architects Revit File |
Fri, Feb 6, 2009 at 12:47:49 PM
.sat importing |
Sat, Mar 29, 2014 at 10:44:49 AM
