Forums >> Revit Structure >> Technical Support >> Concrete Pilaster at wall intersection
Mon, Sep 27, 2010 at 1:57:15 PM | Concrete Pilaster at wall intersection
quentin4d
What is the best way to make this concrete pilaster (attachment is a 3d solid from autocad).
Can the pilaster intersect and remove 2" from the 8" concrete wall? Or should I create a separate 6" wall beside the pilaster?
 I am open to other suggestions as I am fairly new to Revit.
Mon, Sep 27, 2010 at 3:24:45 PM | Concrete Pilaster at wall intersection
You could use an architectural column.  It will assume the materials of the wall.
Mon, Sep 27, 2010 at 3:27:20 PM | Concrete Pilaster at wall intersection
quentin4d
I should clarify that it's not the Pilaster itself that I am curious about. It's the wall portion next to it.
Mon, Sep 27, 2010 at 3:44:58 PM | Concrete Pilaster at wall intersection
You could drop an in-place void family in that location to cut the wall.  NOTE:  a short thinner wall could be problematic because you are at a corner ... hard to clean up properly sometimes.   Might try it first though so you can see the consquences in plan (line) and elevation (line).
Tue, Sep 28, 2010 at 10:59:44 AM | Concrete Pilaster at wall intersection
quentin4d
I made a void, using Model Component in Place, there is no Void Family Category, so I made it part of Structural Foundations, and called it Void 1.
The void was a success, but can I copy it to all the other locations on the model where it applies? It seems I can copy it , but I can't use it to cut the wall again. I don't want to have to do the same process over and over again.
Tue, Sep 28, 2010 at 11:16:08 AM | Concrete Pilaster at wall intersection
You can set the category for any in-place family including voids and I suggest you make this one walls.  Each time you copy this void, you will have to reset it to cut the new wall at that location.
BUT - there is a better answer.  You did not say you had multiple locations.  In-place families are best used for single or maybe two locations.  Otherwise, you should create a family.  In this case, you could create a wall hosted void or a face hosted void and place that family at each of your locations.  (I prfer face hosted void familes that are fully parametric because I can use them in son many different locations.  Floors - ceilings - walls - counters.
A corner pilaster
Mon, Jan 18, 2010 at 6:49:29 PM
Piers/Pilaster joins
Mon, Apr 28, 2008 at 8:50:54 AM
Pilaster
Sat, Jun 30, 2007 at 10:15:22 AM
why the line?
Thu, Jan 21, 2010 at 12:08:36 PM
Placing window at intersection of 2 precast concrete panels
Sat, Jan 5, 2008 at 7:57:00 AM
Page generation time: 1.5809
