Forums >> Revit Building >> Technical Support >> Family with yes/no parameter
Mon, Sep 27, 2010 at 11:47:00 AM | Family with yes/no parameter
cryanbrandon
I have built a workstation family, with yes/no parameters for different options on the workstation.  Now I have placed in project and then go back to update a parameter in the family file and reload the file back in it automatically defaults all the workstations already placed to all parameters on, which overides what is already selected in the project.  Thanks
Mon, Sep 27, 2010 at 12:17:31 PM | Family with yes/no parameter
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
When you update a family and reload it into a project it give you two options. On is just to update the family and the other is to update override all parameters. you need to select the first one and it will just simply reload the family and not change the values set on all parameters.
Mon, Sep 27, 2010 at 12:43:39 PM | Family with yes/no parameter
cryanbrandon
Thanks i should have known better.
Add Family name to a shared parameter
Tue, Jun 23, 2015 at 8:50:48 AM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ]
Tue, Aug 27, 2013 at 3:53:53 AM
29
Family with coordinate parameter? - Revit 2010
Wed, May 12, 2010 at 3:45:58 AM
11
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
top/base constraint as a parameter in family types
Wed, Sep 9, 2009 at 4:49:38 PM
Page generation time: 1.2409
