17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Can't Make Type - curtain wall panel on imported rhino mass
8 Posts No Rating |
Hi everyone, I'm trying to make a curtain system from a mass shape for the first time and I'm running into a little bit of a problem. I imported the mass from rhino fine, but when I started making the surfaces into my custom panel I ran into a few issues. About half of the faces converted to the custom panel fine. The other half gave a "can't make type" error and replaced the custom panel with the typical glazing panel. I'm assuming this means there is something wrong with the custom panel I created, but I don't know what the issue is. I'm using Revit 2011 on a Windows 64 bit machine. Any help you could offer would be great. I've attached an image of the project and also the file for the custom panel. Thank you, Michelle
You need to create your panel using the curtain panel template and don't add controlling dimensions. The reference planes in that template will control your panel.
Rhino imported as mass |
Tue, May 7, 2013 at 12:58:00 AM
Curtain panel - ''wont make type'' - Please help |
Tue, Apr 23, 2013 at 8:10:58 AM
Adding a material to a mass imported from Rhino |
Fri, Oct 22, 2010 at 2:27:31 PM
Filtering curtain panel schedule by type |
Mon, Nov 4, 2013 at 9:10:40 AM
Creating curtain wall system on an angled wall |
Fri, Dec 16, 2011 at 4:01:22 AM
