Forums >> Revit Building >> Technical Support >> Clean up Demolish Wall...
Sat, Sep 25, 2010 at 8:16:59 PM | Clean up Demolish Wall...
buzzwordy
Hello there,
I am working on a project in which there are some walls will be demolished. The problem is some of the walls don't show probably on the plan. There is a line missing where the demolished wall joins with the existing one ( as shown in the image below).
I have been trying to show this problem for days I could not figure out how to do it probably. Before I demolish the wall I use the split tool to seperate the parts that will be demolished however it does not work.
Thanks for your help
Mon, Nov 8, 2010 at 11:46:20 AM | Clean up Demolish Wall...
cbieser
1 Stars: 1 Votes
Select the demolished wall, right-click on the blue dot at the end of the wall, and select Disallow Join.
Mon, Nov 8, 2010 at 7:52:01 PM | Clean up Demolish Wall...
buzzwordy
Thanks so much for your reply. Really appreciate it.
SANITARY WALL CLEAN OUT
Tue, Jan 26, 2010 at 10:39:24 AM
Wall clean-up
Fri, Nov 21, 2008 at 3:21:12 PM
Clean wall join
Sat, Apr 20, 2013 at 3:30:48 AM
11
Problem with Curtain wall Mullion clean up at corners
Mon, Apr 7, 2008 at 9:53:09 AM
Demolish wall alyer
Fri, Aug 1, 2014 at 10:37:24 AM
Page generation time: 1.1977
