Forums >> Revit Building >> Technical Support >> Applying Parameters to sweeps
Fri, Sep 24, 2010 at 8:00:15 PM | Applying Parameters to sweeps
ckplanners
I am trying to make a Parametric.  I seem to not be able to apply a depth parameter. I Have tried everything to know avail.
This is a sink for a commercial kitchen.  The profile is shaped like a fishhook extending down vertical  from the drainboard top about 10" inches straight and then a 3/4" radius at the bottom end which forms the cove. The profile is 3/16" thick the entire length including the radius at the bottom end.  I can make the sink no problem the sketch path is connected to the drainboard reference plane. I use an extrusion for the bottom which is also 3/16" thick. When i dimension and apply the parameter for sink depth it will not stretch down or up for that matter.
I gave up and tried a different method to make a solid extrusion for the sink and then a void extrusion to carve out the sink. There are two many pieces and procedures to make this a practical solution. I know this can work as a sweep and one extrusion for the bottom.
I would really appreciate any help to make this work.
I am using Revit Architecture 2011.
Thank you in advance for your help!
David
Sat, Sep 25, 2010 at 1:08:31 PM | Applying Parameters to sweeps
ckplanners
After 4 days of research i finally found my answer. Was not all wasted though i learned a lot about everything else.
The problem was with the profile Arc point at the bottom was not locked to the reference plane that i labeled "SinkBottom".
I finally discovered the problem and quickly found the solution.
Thanks anyway.
In-Place Family sweeps issue
Tue, May 15, 2007 at 4:56:50 PM
Revit 2012 crashes applying wall sweeps
Tue, Feb 26, 2013 at 9:43:55 PM
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Family material parameters duplicating issue
Tue, Mar 11, 2014 at 2:27:48 AM
Page generation time: 1.2089
