28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> can Callout duplicate detailed drawn on section view?
12 Posts No Rating |
I have some details I drew on a section view, then I made call out of those detail. In the callout, i'll put in even more detail. Is there a way to duplicate the details I drew on the section view in the callout automatically (like a mirror) They're all detail lines. Thank you.
Detail (drafting) lines are view specific, you can't create a call out that will show these lines, but... you can create the callout and copy paste the line work or you can duplicate the view with detailing which will take all your lines across or you can freeze the view to create a new drafting view out of it...
Model view callouts are exactly the same place as the parent view so when you copy from the parent, you can paste same place to the detail or vice versa. Just window and filter for what you want. When I update items like this, I often erase the detail elements that were there in the destination view and then I don't have to be as selective in the copy.
5 Posts No Rating |
you can create a detail group of the "macro" detailing and copy the group to the "micro" detail. if you change the macro, the micro will update or vice versa. you can also include detail components.
1 Posts No Rating |
how do you copy and paste the line work?
Detail Set-up - callout or duplicate... |
Mon, Feb 6, 2012 at 9:24:54 AM
duplicate construction section with detailing error |
Fri, Jun 24, 2005 at 5:21:58 PM
Callout: Detail view vs. Building section RAC 2008 |
Mon, Sep 24, 2007 at 2:05:38 PM
Callout/ Section/ Elevation marks on parallel plans |
Wed, Feb 22, 2006 at 5:56:30 PM
Duplicate views create duplicate callout tags in referring views... |
Fri, Mar 9, 2012 at 1:37:25 PM
