27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Title block labels
7 Posts No Rating |
I am using Revit 2010, and can't seem to get all of the labels I create in the title block template to show up in an actual sheet. The label "Project Issue Date" comes through fine, but one that I created called "Issued for Bid" does not come through on the sheet, even though all of the parameters seem to be exactly the same as "Project Issue Date." Is there something I'm missing? Thanks,
Did you load your custom parameter into the project as a project parameter after you loaded the title block? If you select your title block, and all you see is a question mark that appears but you can't modify it you will need to load the parameter as a shared project parameter. If you are unsure of the process look in the help file.
Title Block labels |
Sun, Apr 8, 2007 at 10:04:03 PM
Title Block Labels |
Wed, Feb 14, 2007 at 11:52:49 AM
Title Labels [ 1 2 ] |
Sat, Jun 29, 2013 at 12:54:18 PM
15
Labels in title block literally gone in project |
Thu, Nov 20, 2014 at 8:22:22 AM
Title block labels not appearing in projct |
Thu, Aug 22, 2013 at 5:36:25 PM
