Forums >> General Discussion >> Revit Project Management >> Keynote Text Wrapping
Thu, Sep 23, 2010 at 8:27:36 AM | Keynote Text Wrapping
olsonda
How do you wrap text in a keynote?  I know it can be done because I have one keynote that did it on its own.  Where is this setting controled from?  Any help you could offer would be appreciated.
 Darek
Fri, Sep 24, 2010 at 1:27:55 AM | Keynote Text Wrapping
eldados
eldados Avatar
4.5 Stars: 8 Votes
edit your keynote family and drag the lable tab to the the length you want the text to start wrapping. (make sure it's the Description lable and not the Code lable)
reload into your project and it should wrap now.
Integrator
KarelCAD
Mon, Sep 27, 2010 at 12:50:06 PM | Keynote Text Wrapping
mikerthebiker
@olsonda
It occurred to me that you may wish the text box size of the keynote to be editable while right on the view (similar to other text boxes in Revit annotation).  Sorry... no can do.
The text field of the keynote is similar to the text field in the View Titles.. you can only edit their width in the FAMILY and watch it 'wrap' back in the PROJECT.
I am in hopes that this will be fixed in a future release.
Mike
Mon, Sep 27, 2010 at 1:07:53 PM | Keynote Text Wrapping
TKennedy
4 Stars: 8 Votes
Something I have done (not with the keynote tag, but with a similar tag with text) is create a tag with three different types, wide, medium and narrow. The family had three different labels reading the same parameter, and were different widths so i had several different choices for wrapping. Not perfect, but it got the job done.
Keynote Legend Not Showing Keynote Text
Fri, Sep 6, 2013 at 11:40:59 AM
12
Keynote Text in Schedules
Thu, Sep 11, 2014 at 4:45:04 PM
keynote categories
Fri, Aug 10, 2012 at 3:56:23 PM
Keynote Text
Thu, May 21, 2009 at 6:08:03 PM
Keynote schedule text not kept within text-borders
Sat, Apr 15, 2023 at 7:47:07 AM
Page generation time: 0.1817
