12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> masking only selected elements
Hi there I would like to know if i can use a masking region that will only mask a selected catagory on my model (e.g. a masking region that will only mask ramps. I ask because i have added a break line to my ramp where it goes down, and need to hide the rest of the ramp below which is currently showing up in elevation. at the moment if i mask the region below the break line it will also mask a structural column that continues up and needs to be shown in the drawing. Thanks for any help you can offer me.
Why can't you just use the VG setting - uncheck "Ramps beyond cut line" The ramp will be cut at your view clip height. And if you want that at a different height, just use a plan region there.
Aligned to selected levels. |
Sun, Jul 17, 2016 at 4:49:50 PM
13
Masking Region Colors |
Mon, Aug 8, 2011 at 3:54:43 PM
Revit 2010 Masking Regions |
Mon, Nov 30, 2009 at 4:42:34 PM
Model Visibility & Masking Regions |
Tue, Aug 28, 2007 at 7:48:33 AM
Un-hiding selected Elements when Category is Hidden In Visibility Graphics |
Mon, Oct 24, 2016 at 1:04:57 AM
