23 Users Online (21 Members):
Forums >> Revit Structure >> Technical Support >> EWWW...concrete stairs are ugly
140 Posts No Rating |
I may be way off base here, but here it goes: Stairs are a system family, so I feel limited in what I am asking revit to do. But I feel like Revit has the ability to do it. 1. Can I kane the tread and risers disappear in a monolithic stair.? 2. Can the undersid of the stair be filled solid? Greg
You wrote : "...1. Can I kane the tread and risers disappear in a monolithic stair.?".... What??? and "...2. Can the undersid of the stair be filled solid?"... Again what? <<< If I uderstand this, add an in-place family to fill theis solid.
Sorry. 1. Can I have... I attached a .pdf file. I used a modify cut profile to get the picture I wanted for filling in under the stair
If this needs to be modeled, then add an inplace family under the stairs... concrete.... and in the section, use the linework tool to remove the line between the stairs and this family. Otherwise, in thie section, just add a filled rgion to fill in this area.
Simplicity...Thanks. Greg
AWESOME!!!! Linework tool worked perfectly. So mush easier that I thought. Now I even have rebar cover ( must be adjusted for tread and riser thicknesses). Stile frickin awesome. Thank You WWHub
Concrete Stairs with winder |
Fri, May 30, 2014 at 7:27:58 AM
Creating concrete stairs from raised exterior slab |
Sat, Oct 25, 2014 at 10:26:43 PM
Using in place models to create an existing concrete stairs |
Wed, Sep 24, 2014 at 7:14:40 AM
Hand rails and Stairs |
Wed, Nov 15, 2006 at 5:04:46 PM
Stairs by sketch breaking |
Wed, Mar 12, 2014 at 8:42:58 AM
