25 Users Online (23 Members):
Forums >> Community >> Newbies >> Revit Layers
5 Posts No Rating |
Hi All I am trying to change the colours of an object so that it specifies different colours in the view. For example: The layers for floors are divided into- Structure [1], Substrate [2], Thermal/Air Layer [3], Finish 1 [4], Finish 2 [5], Membrane Layer, Structural Deck [1]. I want to assign a different colour to each each so when in in a section view, the floor will show the finish layers in yellow, the structure in red and substrate in blue. I have tried changing and adding subcategories to object styles but can't get to assign it to the corresponding layers. Is there a way to change this? All help will be much appreciated.
Just assign in the properties of that slab differents colors (materials) and pattern to each layer like you want.
5 Posts No Rating |
I have assigned materials to the slab, what I want to achieve is to be able to have the lineworks showing without having to change it again. It's part of a template. Attached is an image to indicate what I want to achieve and what I have achieved. The top slab is how I want it to look. The bottom slab is how I got it so far. Thanks for the feedback
I don't understand your second post. As Typhoon said... assign materials to each layer. ... and it appears that you have done that, so what is the issue?
If I understand RT correctly he wants to control the color of the linework between the wall layers like autocad. Not sure how that would work because techniclly a wall / roof / floor is made up of adjacent materials that share the same borders and the 'core' perimeter knid of has a mind of his own. I don't think the internal linework is that controlable? I only use color for MEP. All my Arch and Struct is old school black and white but using color is not a bad thing. Just not in this application.
Is this what are you talking about?
Ahhhh forgot about that. Great find.
5 Posts No Rating |
Thanks guys for the info. This is exactly what I have been looking for.
Changes to AutoCAD layers when imported to Revit |
Wed, Oct 29, 2008 at 10:35:39 AM
DWG/DXF layers. |
Wed, May 31, 2017 at 7:05:57 AM
Scheduling Wall Layers |
Wed, Nov 4, 2015 at 11:24:08 AM
Glitch with several layers of glass? |
Thu, May 3, 2007 at 1:29:00 PM
AIA Standards- Revit to AutoCAD layers |
Thu, Feb 1, 2007 at 12:50:29 PM
