Forums >> Revit Structure >> Technical Support >> How do you add a wall sweep to a beam system?
Tue, Sep 21, 2010 at 4:30:36 PM | How do you add a wall sweep to a beam system?
MagellanTX
I am trying to create a stud wall with RAC2010 and I've seen samples where people have used beam systems for the studs and the top plate and bottom plate were actually wall sweeps but I can't figure out how they were attached.
Thanks!
Edited on: Tue, Sep 21, 2010 at 6:09:30 PM
Beam System problem
Wed, Jan 16, 2008 at 12:09:21 PM
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:20 PM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
BEAM SYSTEM BEARING ON WALL
Wed, Sep 19, 2012 at 8:28:28 AM
beam system
Wed, Apr 22, 2015 at 10:35:51 PM
Page generation time: 1.6959
