Forums >> Revit Building >> Technical Support >> Exporting Revit to .dwg files for use by consultants
Wed, Oct 19, 2005 at 10:35:33 AM | Exporting Revit to .dwg files for use by consultants
TracyA
My consulting MEP Engineers are complaining about my exported .dwg files. The issue is that when Revit converts to a .dwg it breaks the lines of a wall into several lines that are not continuous and sometimes lines are on top of lines, etc. Their biggest grip is that when they try to use snaps they never know where it's going to pick, usually not where they wanted. Does anyone know if there is a setting somewhere to resolve this. Any feedback would be greatly appreciated. Thanks in advance. Post edited on 2005-10-19 10:46:53
Wed, Oct 19, 2005 at 9:29:54 PM | RE: Exporting Revit to .dwg files for use by consultants
antfa
Hi Tracy, Try checking your export options, and make sure "Merge collinear wall lines" is ticked. Also check the layer settings and load one of the defauls, the "exportlayers-dwg-ISO13567.txt" works well for us. I hope this helps Regards Antfa
Wed, Oct 19, 2005 at 11:16:08 PM | RE: Exporting Revit to .dwg files for use by consultants
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you are still having issues you can use the overkill command in autocad to remove overlapping lines and link adjacent lines etc...
Wed, Oct 19, 2005 at 11:42:38 PM | RE: Exporting Revit to .dwg files for use by consultants
Scott Davis
3.5 Stars: 3 Votes
What version of Revit are you using? Revit 8.1 had some things changed to give much better exports of DWG, including the ability to remove 'colinear' lines. Be sure to upgrade if you are suing anything less than 8.1.
Exporting issues... exported dwg files missing information
Thu, Jan 24, 2008 at 11:43:21 AM
Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
Mon, Mar 21, 2011 at 3:03:58 PM
Compound Ceiling Grid Not Exporting to DWG
Mon, Jul 8, 2013 at 9:53:46 AM
Exporting revit to DWG files
Fri, Nov 10, 2006 at 4:29:06 AM
Revit to DWG in one single flie.
Mon, Sep 22, 2014 at 4:01:47 PM
Page generation time: 1.5362
