Forums >> Revit Building >> Technical Support >> green model lines
Tue, Oct 18, 2005 at 5:48:12 PM | green model lines
arccodex1
3 Stars: 1 Votes
I get a lot of use out of the thin, medium, wide, and other linestyles, but can someone explain what the green "Lines" are for? Is there a reason why Revit sets these up by default?
Tue, Oct 18, 2005 at 6:44:35 PM | RE: green model lines
eldados
eldados Avatar
4.5 Stars: 8 Votes
from Revit Help: ..."Model lines exist in 3D space and are visible in all views. NOTE: If you want to draw lines that exist only in the view that they are drawn, see Detail Lines." Smile
Integrator
KarelCAD
Thu, Oct 20, 2005 at 1:35:51 PM | RE: green model lines
arccodex1
3 Stars: 1 Votes
I meant what are the green detail lines for not model lines. They seem to plot too thin to be usefull.
Thu, Oct 20, 2005 at 4:50:19 PM | RE: green model lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just another built in linestyle. Its up to you if you use it or dispose of it.
Wed, Sep 7, 2016 at 10:03:40 AM | green model lines
Svetlana1964
How to get rid of thouse green lnes or how to mak them black?
Thu, Sep 8, 2016 at 9:46:40 PM | green model lines
CarloGae
try on v/g overides or object styles in manage tab
HTH
Fri, Sep 9, 2016 at 7:20:56 AM | green model lines
marmiketin1
4.5 Stars: 10 Votes
you can change the 'Lines' line type colour under manage tab > additional settings > line styles and then expand the + and go down to 'Lines'
Edited on: Fri, Sep 9, 2016 at 7:22:56 AM
Fri, Sep 9, 2016 at 10:30:19 AM | green model lines
Svetlana1964
Unfortunately, nothing would work. It is still green
Fri, Sep 9, 2016 at 11:36:06 AM | green model lines
marmiketin1
4.5 Stars: 10 Votes
This is a list of all my line styles and their properties. Changing the 'Lines' at the top which shows as green doesnt do anything. There is a default 'Lines' category half way down that is green that changes. If that doesnt work then unless you post your project it is difficult to determine the issue.
3D component strangeness, green lines and not visible in 3d
Fri, Aug 8, 2014 at 7:28:02 AM
Green object lines
Mon, Sep 12, 2016 at 9:40:03 AM
Edit Cut Prolie Green Lines?
Sun, Apr 11, 2010 at 8:25:44 AM
RAC2009 - > green lines in 3d view
Thu, Aug 21, 2008 at 11:12:33 AM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Page generation time: 0.6443
