13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Library Components, Metric and Imperial
Hi All,I have RAC2010, and have loaded the Metric library, if I need to load Imperial library , how do I do it? b) Can we have both the librarys loaded together and if so how do we do it? and are there any implications such as slowing of the system due to it. Your suggestion would be appreciated, thanx in advance
yes you can, but why?? if you are using metric in your office (country) than you don't need the Imperial library, it's the same content just with imperial units... there is no extra load on Revit, you can add as many libraries as you want, it's only a path in Revit to where your library sits.
1 Posts No Rating |
hi everybody do you know if i setup the Material Library is that mean that i have metric & Imperial components or no? how could i load these in to my revit?
Yes you can load more than one library.
In windows do the following:
Control Panel --> Add Remove Programs --> Select Revit --> Uninstall/Change
When you do this it will give you 3 options: Add of Remove Features, Repair or Reinstall, or Uninstall.
Select Add or Remove Features and you can add more libraries.
I for one like to use both, as I do projects in both metric & imperial countries, and the default library is not the one I use most.
www.globaldesignstudio.com
Be Inspired! |
showing metric and imperial elevations |
Thu, Jun 3, 2010 at 3:34:46 PM
Imperial metric question RAC2009 |
Fri, Jan 9, 2009 at 11:35:51 AM
Nwe user: Using Revit in Imperial and Metric units |
Sat, Sep 29, 2007 at 9:57:47 PM
Change from Metric to Imperial |
Sun, Feb 17, 2013 at 9:26:03 AM
Imperial to Metric |
Fri, Aug 8, 2008 at 4:11:17 PM
