Forums >> Revit Building >> Technical Support >> Project Templates
Fri, Sep 17, 2010 at 11:06:21 AM | Project Templates
SteveB
3.5 Stars: 5 Votes
After you have created a project with schedules, all the "transfer project standards" related stuff, sheets, etc, you can "saveas a template".  All good, except that saves all the building model info, details, etc.  Is there a way to do this without having to manually delete all of the drawing information and just have the "blank canvas" similar to the revit pre-loaded templates?
Fri, Sep 17, 2010 at 2:23:14 PM | Project Templates
You only have a couple of options:
  1. Start a new template and transfer ...copy / paste what you need to create it or:
  2. Delete the model content from what you have.
I would do #2 - fairly easy.
  1. Just go to a 3D view - make sure all model elements are on, window and delete.
  2. Goto a plan and delete all column lines
  3. Goto an elevation and delete all but two levels... your choice
  4. Using your shift key, pull down through you views in your browser high-lighting what you don't want and delete from the browser. (Leave the plans associated with the levels you kept).  Leave the NSEW Elevations
  5. Do the same for the sheet views.... I would leave some and clean up your title sheet.
  6. Goto your room schedule and delete all the rooms that are left.
  7. Go through your legends and discard what you don't want.
Transfer Project Standards - View Templates
Mon, Aug 29, 2011 at 12:03:03 PM
Managing Family Templates
Fri, Apr 29, 2016 at 3:40:54 PM
Revit Structure Project Templates
Wed, Apr 18, 2012 at 5:29:56 PM
Templates
Wed, Oct 3, 2007 at 10:50:13 AM
Templates by Unit?
Thu, Jan 12, 2017 at 1:39:47 PM
Page generation time: 0.4688
