Forums >> Revit Building >> Technical Support >> Geodesic Dome
Tue, Oct 18, 2005 at 1:35:16 PM | Geodesic Dome
OzMan
I've been asked to layout a residential plan for 40 foot diameter 5/8's 3 frequency geodesic dome. I found a program that generates the geometry in 3d in a dxf format: http://www.applied-synergetics.com/ashp/html/domes.html and I have a wire frame model in AutoCAD. The geometry does not explode in AutoCAD. If I link the drawing in Revit it disappears. If I import and try to explode it, it disappears. I do this in level 1 view and when I try to see it in 3d, it diappears. Question 1 - Why I'm I having these problem with this dwg. Why doesn't this generated shape act like other ACAD drawings Question 2 - Once I place this geometry in Revit, how do I turn it into Revit model? Trace it? Should I create indiviual triangular panels with framing and skin, how do I place them, nothing is plumb. How would I create a triangle panel in the first place? Should I try to this with Mass and "wall by face"? Modeling "creat in place"? Is this doable, or should I stick to AutoCAD on this one? Thanks
Tue, Oct 18, 2005 at 6:47:03 PM | RE: Geodesic Dome
eldados
eldados Avatar
4.5 Stars: 8 Votes
create a mass family and import your dwg into the family, create walls by face and load it into your project... HTH
Integrator
KarelCAD
Tue, Oct 18, 2005 at 8:43:56 PM | RE: Geodesic Dome
OzMan
I imported the drawing into a new project and went to mass editor. The drawing acts like a block (is that the correct term for Revit?) I can't do "wall by face" because the whole drawing acts like a whole and not the parts. I exploded the drawing and lost all the 3d info? How do I access the individual parts of the imported drawing? I'm new to Revit, so please excuse me if I miss something from you post.
Tue, Oct 18, 2005 at 8:53:40 PM | RE: Geodesic Dome
eldados
eldados Avatar
4.5 Stars: 8 Votes
make a new mass family, not a new drawing... and follow the steps above. can you send me the file, I will have a look at it when I get some time.. wishful thinking Smile
Integrator
KarelCAD
Wed, Oct 19, 2005 at 2:46:53 PM | RE: Geodesic Dome
Thread Post Kudo! #5
OzMan
Wow, that's impressive. When I imported the drawing, the mass family took on the geometry automatically. Now I assume I load the new mass into a new project and proceed to wall by face. Your previous post said to: 1 create family, 2 import dwg to family, 3 walls to face, and 4 load into project. But at this point I can not do "wall by face", only "load into project" This is starting to become fun.
Wed, Oct 19, 2005 at 6:41:17 PM | RE: Geodesic Dome
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes that's correct, load it into your project and wall by face or the curtain system... the DOME program is cool! and what's even cooler is that it's running in Linux! Smile i loaded the family into a project and was able to use walls... have fun
Integrator
KarelCAD
Wed, Oct 19, 2005 at 7:51:05 PM | RE: Geodesic Dome
OzMan
Are you into domes? Most people I know associate them with old hippies. So it's unusual to have someone ask me to do one. I'll have more questions, and let me know if you discover any cool Revit tricks to do with this geometry.
Wed, Oct 19, 2005 at 7:56:17 PM | RE: Geodesic Dome
eldados
eldados Avatar
4.5 Stars: 8 Votes
I like geodesic domes very much, it is a very strong and clever, i know there is a company around your area that sell geodesic homes as a kit, using 2 meter triangle pieces, it looks cool Smile it is very good for high wind area, because the wind just creates a down pressure on the dome! have fun with it and no I'm not a hippie! Smile lol
Integrator
KarelCAD
Wed, Oct 19, 2005 at 11:27:33 PM | RE: Geodesic Dome
OzMan
It worked, thank you. The only problem is, I have about 5 panels that are on the outside of the shell instead of the inside. I can't find the "flip" symbols and right clicking on the panel does not give me the option. How do I correct it? My client are looking at concrete domes from this company: http://www.aidomes.com/default.html. It's a concrete shell and is also fire rated, which will be important in it's forest setting. We're looking to be off the grid. The price of about $23,000 offset the shipping cost from across the country, considering building cost in California. I got to see R. Buckminster Fuller speak in the 70's. He had a lasting impression on me. Does that make me an old hippie?
Geodesic Dome
Wed, Apr 4, 2007 at 9:11:27 PM
geodesic dome space frame
Sat, Apr 2, 2005 at 7:42:13 AM
Create a half dome
Mon, Nov 11, 2019 at 5:37:42 PM
How to draw this type of roof in revit.
Mon, Aug 18, 2008 at 4:38:13 PM
Dome roof
Mon, Jan 17, 2011 at 7:52:22 AM
14
Page generation time: 0.0435
