Forums >> Revit Building >> Technical Support >> Revit Architecture (Student Version) 2011 problems?
Fri, Sep 17, 2010 at 9:52:00 AM | Revit Architecture (Student Version) 2011 problems?
Scrybe
Scrybe Avatar
I downloaded and installed the Revit Architecture 2011 student version from the Autodesk Student Community website last week. It's running mostly ok.
Two major areas that I'm having problems in, however:
One, is that when I go to render any part of a design, it omits large numbers of images and materials from the objects. The objects themselves all come out either pastel white, looking almost like a bland yogurt, or just replaced with a big black space where the floor or the ground should be. It isn't just the foreign jpg samples that are missing now, either. Its the standard materials package that comes with the software that disappears too.
For example, the first attached picture should have blue carpet below the couch, and terra cotta red tile around the pool. In the second (Living Room) the stair runners, and the funiture should be black, an there should be metal and such in hte TV and coffee table. In the third (House), it should be an ash colored brick house with red solider course around the windows, but in it even the grass in the yard is somehow omitted.
Two: When I try to go in and redirect the material image back to the file, or even when I just try to change anything about any material, the entire program crashes, and shuts down. Usually this happens after I've made the adjustments, hit "ok" and tried to return to the drawing. And, of course, when it crashes, I lose every adjustment I've just made.
Are these just problems with the Student Versions of the software, or has it been showing up in the full versions, too? Or is it hardware problem on my end, or something?
Fri, Sep 17, 2010 at 10:05:52 AM | Revit Architecture (Student Version) 2011 problems?
4 Stars: 205 Votes
Maybe this is the problem: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15255349&linkID=9243099
also check this:  http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15387494&linkID=9243099
Fri, Sep 17, 2010 at 10:59:08 AM | Revit Architecture (Student Version) 2011 problems?
Scrybe
Scrybe Avatar
Nope. Still crashed. Next?
Is RA 2011 meant to run on Windows 7, maybe? I'm still on Vista?
Fri, Sep 17, 2010 at 11:12:17 AM | Revit Architecture (Student Version) 2011 problems?
4 Stars: 205 Votes
It work fine in VISTA too, that's not the problem, what's the SPEC of your machine? Processor, Ram, graphic card......
Fri, Sep 17, 2010 at 11:31:35 AM | Revit Architecture (Student Version) 2011 problems?
Scrybe
Scrybe Avatar
HP TouchSmart
Intel Core2 Duo CPU T6400 @ 2GHz
4GB RAM
500GB Hard Drive
64-Bit OS
Not sure what the video card situation is.
Fri, Sep 17, 2010 at 1:07:28 PM | Revit Architecture (Student Version) 2011 problems?
4 Stars: 205 Votes
Do you receive the “The following render appearance images are missing:” warning when rendering?
Ensure the windows temp folder is not full, use software like "Ccleaner" to clean those temp files,  check in Option if you have the path in Rendering - Aditional render appearance paths
Edited on: Fri, Sep 17, 2010 at 1:17:03 PM
Sun, Nov 21, 2010 at 9:06:03 PM | Revit Architecture (Student Version) 2011 problems?
davepsanders
I am running Revit 2011 Student Version on Windows 7 and I am having the same issue. I went to the suggested links and this was not the issue (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15255349&linkID=9243099).
Has anyone had any success fixing this?
Thanks.
Mon, May 23, 2011 at 12:42:42 AM | Revit Architecture (Student Version) 2011 problems?
bebenciuki
I have the same problem with crashing when I try to change material options, but it just started.
 it never happened before. Maybe you succeeded fixing the problem?
Mon, May 23, 2011 at 3:45:54 AM | Revit Architecture (Student Version) 2011 problems?
vector23
vector23 Avatar
2 Stars: 16 Votes
the student version may have watermarks or something
but it's no different than any other revit.. i would save what
i have and reinstall revit.. you need clean installations- even
with windows.. too many things can corrupt any program..
Mon, May 23, 2011 at 4:04:57 AM | Revit Architecture (Student Version) 2011 problems?
bebenciuki
I tried it. and it still does the same, even in new empty project it is hopeless... And I must finish my project until tomorrow :D thats not funny...
Mon, May 23, 2011 at 11:18:15 AM | Scrybe
#11
vector23
vector23 Avatar
2 Stars: 16 Votes
Quoting Scrybe from 2010-09-17 09:52:00
go into the "materials" dialog and highlight the "default" material.. go down to the
duplicate command and create "default 2" and change that name to some part of
your model you want to render so you will remember what it's for.. then hit the
"render appearance" tab and then hit "replace"- chose a material- then close that
all out and go back to your project and find the "paint" tool.. with the paint tool is
a list of all the materials you have chosen.. (something changed with that for 2012
but you'll see it)- and then make sure you are in a 3D view and not a perspective
 view- and "paint" the part of your model you want to render that material..
Mon, May 23, 2011 at 11:28:17 AM | bebenciuki
#12
vector23
vector23 Avatar
2 Stars: 16 Votes
Quoting bebenciuki from 2011-05-23 00:42:42
"I have the same problem with crashing when I try to change material options"
there will always be a time when you are changing materials and colors
back and forth so many times that the program cannot deal with YOU-
and it will politely CLOSE.. that's one good reason to constantly SAVE
your work.. it's the same thing with windows 7- if you get too "carried away"
changing eye candy back and forth like you are losing your mind- windows
will basically tell you it's had enough and will close down..
Mon, May 23, 2011 at 11:55:31 AM | Revit Architecture (Student Version) 2011 problems?
#13
bebenciuki
I found the problem. tablet driver didn't make friends with revit. I just had to disable it, and everything works perfect again :]
so I'm not so crazy material changer :D
Tue, May 24, 2011 at 8:53:56 AM | Revit Architecture (Student Version) 2011 problems?
#14
blitz3dservice
I'm not familiar with the procedure to backup the registry.  Can you explain how to do this?  Where is this registry (file name/ extention) located?  Would this be located in the Windows directory?
3D service
Tue, May 24, 2011 at 10:48:13 AM | Revit Architecture (Student Version) 2011 problems?
#15
bebenciuki
You have to go to "task manager" (ctrl+alt+del) then go to services find services button. from the list in the new opened window find "tablet pc input service" double click. than in "start up" menu choose "disabled" and ok. thats all :] hope it will help you too.
re-downloading Revit student version
Fri, Feb 19, 2010 at 12:23:08 PM
Re-installing Revit Architecture 2011
Tue, Dec 13, 2011 at 1:26:18 PM
File in Student Version transfers to Professional Version
Mon, Jul 26, 2010 at 12:06:11 PM
Revit Sheet Sets-Student Version
Fri, Apr 22, 2016 at 5:45:59 PM
revit student version
Mon, Oct 5, 2009 at 3:23:39 PM
Page generation time: 2.2548
