Forums >> Revit Building >> Technical Support >> Mouse: Selecting item causing compent to jump up page
Fri, Sep 17, 2010 at 7:41:07 AM | Mouse: Selecting item causing compent to jump up page
bdbhoy
1 Stars: 1 Votes
Revit Architecture 2011
Mouse Problem
Can't figure out if it's mouse setting, computer, or programme issue
Programme/mouse working normally until a few days ago.  How when I select door/window/wall/sheet/dimension/or component the item 'jumps' up the screen proportiuonally to how close zoomed in, (Occuring in plan & elevation, but does not happen with a door restrained in wall orientated left to right across screen) .
I've tried a number of different wireless and wire mice, same result. Altered control panel setting to restore default, no change.
I have the programme installed on and old computer as a reference monitor/backup. I've tried the same mice on that and the programme performs correctly.
Any possible suggestions where to attempt to solve?
Fri, Sep 17, 2010 at 9:07:54 AM | Mouse: Selecting item causing compent to jump up page
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
We had the same issue happen to one of our end users and we just ended up rebuilding his Windows profile...worked like a charm.
We also tried updating all drivers, resetting the ribbon, deleting the communication center file and a ton of other stuff and none of that worked.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Sep 17, 2010 at 9:27:33 AM | Mouse: Selecting item causing compent to jump up page
Turn off drag and drop...lower right corner of your screen.  You are moving the object.
Fri, Sep 17, 2010 at 9:39:18 AM | Mouse: Selecting item causing compent to jump up page
brettgoodchild
4 Stars: 17 Votes
Hub is talking about the Press & Drag check box in the bottom right corner.
I have mine turned off to avoid moving something accidently as I am panning around the models.
This will work but elements should not move when they are selected even if press and drag is checked.
When this happend to us, it was right after some Windows updates were installed and after the massive amounts of updates that happened this recently...one of them may be to blame.
                             ~ Abraham Lincoln
Fri, Sep 17, 2010 at 9:40:02 AM | Mouse: Selecting item causing compent to jump up page
bdbhoy
1 Stars: 1 Votes
Many thanks, that's the problem solved. Doh, what a waste of 4 hours.
Fri, Sep 17, 2010 at 9:45:25 AM | Mouse: Selecting item causing compent to jump up page
bdbhoy
1 Stars: 1 Votes
To Mr brettgoodchild,
Your probably correct  I had a long windows update two mornings ago, automatic restart and (thinking about it with hindsight) the problem began.  I've never turned on, used, or understand the 'press and drag' function, (until it's wasted my day).
Fri, Sep 17, 2010 at 9:59:13 AM | Mouse: Selecting item causing compent to jump up page
bdbhoy
1 Stars: 1 Votes
Turning off 'press and drag' solves my problem, but I just noticed my old machine (revit 2011 installed) has this function activated and does not cause the components to jump up the screen. Also slight flicker over whole drawing when selecting component on main machine (with 'press and drag' turned off), though its location does not alter at random - which happens when turned on.
Fri, Sep 17, 2010 at 10:09:05 AM | Mouse: Selecting item causing compent to jump up page
Sorry about the terminology guys... I'm at home and forgot it was Press and drag not Drag and drop... Getting to old to remember.
Fri, Sep 17, 2010 at 1:46:16 PM | Mouse: Selecting item causing compent to jump up page
brettgoodchild
4 Stars: 17 Votes
HAHA!!
Whatever Hub, for an old guy, you can hold your ground against anyone out there.
                             ~ Abraham Lincoln
Fri, Jan 21, 2011 at 8:41:04 AM | Mouse: Selecting item causing compent to jump up page
Thread Post Kudo! #10
eriks
press and drag is not the reason why this all hapens, i read in a post somewhere on this forum, i've forgotten where exactly, that you have to dock the options toolbar at the bottom of the screen instead of at the top of your screen. that solved the problem for me, and dried my tears. (with options toolbar i mean the bar wich appears when you add a wall, where you can fill in the offset distance etc.)
chrz Erik
Fri, Jan 21, 2011 at 10:23:30 AM | Mouse: Selecting item causing compent to jump up page
brettgoodchild
4 Stars: 17 Votes
Press and Drag is just a way to avoid the annoyance of elements moving upon selection. We tried docking the options bar previously and it had no affect on anything. Autodesk even suggests redocking the Project Browser
See the link for Autodesk's response.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14997251&linkID=9243099
                             ~ Abraham Lincoln
Thu, Mar 29, 2012 at 1:13:58 PM | Mouse: Selecting item causing compent to jump up page
luismendez
Hi there, I used an Applle Display for Revit, and i was having the same problem; each time i click anywhere, the windows started flickering or flashing.... I've deselected the "press &Drag" case but didnt resolve.... After making uptades and trying to fix it, nothing work. Finally after 5 hrs waisting my time, I fixed by the dummiest way i imagine:
Under the ribbon, there is a line that actiates when you select a title block or something, right click and select "Dock at Bottom".... anyways that solve my problem.
Fri, Aug 17, 2012 at 6:32:25 AM | Mouse: Selecting item causing compent to jump up page
#13
dkido
dkido Avatar
Thanks all. I think you just saved me many many hours of trauma, of cause on a tight deadline.
Wed, Mar 6, 2013 at 4:33:51 PM | Mouse: Selecting item causing compent to jump up page
#14
bsf
Thanks Eriks.  I also had this problem and docking the options panel at the bottom fixied it.  Press and drag had nill affect.
Highlight when selecting
Wed, Jun 29, 2011 at 4:05:28 PM
Revit Family causing print issues
Wed, Jan 6, 2016 at 10:08:30 AM
can't downnload families
Mon, Dec 22, 2008 at 5:47:55 AM
Mouse Speed
Tue, Jul 19, 2011 at 4:48:43 PM
MOUSE PROBLEM
Mon, Nov 23, 2009 at 11:08:32 AM
Page generation time: 0.4267
