12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> Cannot detach from central !!! plz help !!!
Every time i go to detach the model from the central file and save it, it some how reverts itself back to a central file. Ive took myself off from all the worksets and made sure that ive relinqished myself before i go to detach but it still wont work !!!!what im i doing wrong, can anyone help with this annoying problem ?????
When you open a file in Revit - even detached, you still have to use the save - as function and check the "make this file a central" box..... and you need to give it a different name.
so is there a way of making a model with worksets activated into a standalone file by detaching it ?
Once you make a file workshared, it will alway be workshared.
"Once you make a file workshared, it will alway be workshared." and "alway" means always
detach from central file |
Wed, May 12, 2010 at 12:28:23 PM
Detaching from Central Model...I CANT! |
Fri, Aug 27, 2010 at 10:26:55 AM
Detach from central - Linked files |
Fri, Dec 16, 2011 at 12:50:03 PM
can't view file properties - central path |
Fri, Aug 21, 2009 at 2:34:53 PM
Plug-ins? |
Fri, May 8, 2015 at 8:03:35 AM
