Forums >> Revit Building >> Technical Support >> Working With Individual Units as Part of Multi-Unit Project
Thu, Sep 16, 2010 at 8:48:33 PM | Working With Individual Units as Part of Multi-Unit Project
rdavies1973
rdavies1973 Avatar
Hi allExample: a series of terraced houses that won't fit onto a standard page, and how to dimension them ... especially the inside units.Guess 1 is that the answer lies in creating a master file (with the whole plan), then referencing the individual units so they can be worked on seperately. Guess 2 is using matchline.
i.e. What's best approach to work on units/parts of a larger overall project?Am I on the right track, or do I need to give more info about the problem?
Fri, Sep 17, 2010 at 7:00:01 AM | Working With Individual Units as Part of Multi-Unit Project
I doubt that your housing project is much different than a hotel in project organization.  We have overall plans and use matchlines / dependent views when the plan will not fit the sheet.  For individual rooms (units) we call them out from a plan then have seperate sheets that show those plans, interior elevations and details.
Tips on setting up a multi storey and multi unit residential model
Wed, Aug 3, 2011 at 8:35:26 AM
Multi Unit buildings
Mon, Jun 6, 2005 at 2:41:00 AM
Area and Room Tags
Thu, Apr 16, 2009 at 2:48:06 PM
multipanel window with variable sizes
Tue, Apr 19, 2005 at 12:25:41 AM
How to hide rooms in schedule,, show only subtotals?
Tue, May 1, 2007 at 6:47:31 PM
Page generation time: 1.2763
