Forums >> Revit Building >> Technical Support >> this entire project is at the wrong elevation !!!
Thu, Sep 16, 2010 at 7:10:37 PM | this entire project is at the wrong elevation !!!
iamian33
iamian33 Avatar
Greetings.
I have inherited a project that someone else began.  The model is well underway with a site (w/ toposurface).  The problem is that they drew the toposurface, tracing the CAD file, and manually moved it to the "correct" elevation ... by eye ???  The floor levels are set at 0 and not at true datum.
I am now receiving actual suvey info and would like to perserve as much of the original Central File as possible. I have never had much success with moving toposurfaces so I am concerned.
I feel that I can relocate the balance of the model by locking all the levels to each other and editing the main floor to be at the correct elevation.  I will probably have to move a few things (hopefully).  But I'd like to keep all the split surfaces and such.
Any ideas ??
Secondly, I'd like to keep the Levels reading relative to the project (Main Floor = 0).  I've never been a fan of absolute elevations.  Can the Level Marks be changed to "Relative"?
thanks in advance ...Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Thu, Sep 16, 2010 at 7:28:15 PM | this entire project is at the wrong elevation !!!
iamian33
iamian33 Avatar
I think that I've found a thread that addresses the building, but not the toposurface.  If anyone has advice on how to relocate the toposurface to the correct elevation, I'd like to hear ...
Ian
Ian Shafer
Fri, Sep 17, 2010 at 6:55:09 AM | this entire project is at the wrong elevation !!!
Look in the help on how to relocate your project.
Yes, the level marks can be relative...0.00 for level one or whatever or absolute - your choice.
Fri, Sep 17, 2010 at 8:32:28 AM | this entire project is at the wrong elevation !!!
vector23
vector23 Avatar
2 Stars: 16 Votes
iamian-
you can move the surface to any elevation you want
relative to its original base.. but you can't move the
base without creating a whole new base.. that's just using
logic because i have no experience putting buildings
or sites in the wrong place to start.. somebody's
probably not going to like this answer but it's
the best i got and i'm thinking it could be helpful
in some way..
Edited on: Fri, Sep 17, 2010 at 8:35:15 AM
Fri, Sep 17, 2010 at 6:12:41 PM | this entire project is at the wrong elevation !!!
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
In an elevation view you shouldn't have any trouble selecting your levels and your toposurface and moving it upward, with the move tool.   If you move all of your levels at once, you won't have any conflicts.  You don't need to lock them--just select them all.
Topo surfaces couldn't care less about your model or levels.  The move tool in an elevation view should work fine as well.   If you find that the topo points are at arbitrary numbers now that they were moved by eye, know that the bottom points are a good place to start -- move that to a level, and then up/down a rational distance.
Move half of entire project down vertically
Tue, Aug 4, 2015 at 10:35:42 AM
Changing level elevation for entire model on all floors
Wed, Dec 10, 2008 at 7:21:40 PM
How to copy over entire project
Wed, Nov 7, 2007 at 10:38:31 AM
Moving entire building down...
Thu, Jun 23, 2011 at 4:10:34 PM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
Page generation time: 0.8884
