Forums >> Revit Building >> Technical Support >> Tags in Legends not possible....workaround?
Thu, Sep 16, 2010 at 8:37:09 AM | Tags in Legends not possible....workaround?
JeroentjeM
Since it is not possible to tag in legend sheets, i'd like to know if there are any good workarounds for this?
I want to use legends to create in example a sheet for an overview of all my used windows. In this sheet I would like to add information like width,heigth,type,material etc.
This kinf of information could be easy to get with a tag...but that's not possible. Any other ways?
Thanks!
Thu, Sep 16, 2010 at 9:11:31 AM | Tags in Legends not possible....workaround?
You can use material tags in legends and you can dimension window and door legends.
For our windows - especially curtain wall windows, we use an elevation (hidden in plans).  We turn off everything in the elevation except the window.  Now we can use tags and whatever else we need.
Thu, Sep 16, 2010 at 3:25:23 PM | Tags in Legends not possible....workaround?
Bimman
Bimman Avatar
1 Stars: 2 Votes
we do our window elevations the same way Hubb described.
PWD
Fri, Sep 17, 2010 at 1:02:04 AM | Tags in Legends not possible....workaround?
JeroentjeM
Ok, tried this.
The only thing is that you can't put the windows in a nice order? If you move a window it is logically moved in the entire project. How do you do this?
We're used to windowsheets with everything in a nice order, aligned etc....
Fri, Sep 17, 2010 at 7:03:57 AM | Tags in Legends not possible....workaround?
Bimman
Bimman Avatar
1 Stars: 2 Votes
you can place the elevation view any where you want on the sheet. in any order.
PWD
Elevation Tags
Wed, Jun 21, 2006 at 9:13:57 PM
Door and Window Tags in Legends
Tue, Jan 22, 2008 at 2:57:19 PM
Window Schedule en Legends related to window MARKS
Tue, Sep 8, 2009 at 8:00:50 AM
Legends
Sat, Nov 24, 2007 at 12:14:00 PM
Window & Door Legends
Thu, Sep 10, 2015 at 12:41:54 AM
Page generation time: 0.1414
