Forums >> Revit Building >> Technical Support >> Showing Phases on a new Housing Scheme site rendered - R2010
Thu, Sep 16, 2010 at 2:55:58 AM | Showing Phases on a new Housing Scheme site rendered - R2010
ScottMacD
Hi All
Tried searching for this but not able to find anything (maybe using wrong key words)
I am working on a new housing site with 9 blocks of terraced housing, i have created each block separateley, named them Terrace 1-9 then linked them to the main site plan.
Now what I am after is this: Terraces 1-6 are part of Phase 1 with Terraces 7-9 part of phase 2. I am wanting to do a series of renders showing phase 1 with phase 2 greyed out and vice versa and then both in there full glory. i tried going into the relevant terraced model and messed with changing phases, so i changed terraces 7-9 to existing phase which then greyed the model and terraces 1-6 new construction. i then went to my main site plan it didnt show the terraces greyed so i tried a render , but it just rendered them all the same with full texteures.
I cant find anyway within the main site plan to change a linked revit file to either new or existing phase. so is my only way out a bit a photshop magic.
thanks in advance for any advice or help.
Cheers Scott
Thu, Sep 16, 2010 at 3:51:12 AM | Showing Phases on a new Housing Scheme site rendered - R2010
ScottMacD
Scrap the question, I was doing it the correct way for what I want, I just done a test render in the wrong part of the site....Idiot...I need more (or Less) coffee.
multi building site with phases
Thu, Oct 25, 2012 at 10:35:27 AM
color scheme disappear
Fri, Sep 24, 2010 at 7:49:22 PM
Room Colors don't show in R2010
Thu, Aug 13, 2009 at 11:38:19 AM
Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 8:02:56 PM
COLOR SCHEME IN SITE PLAN
Fri, May 29, 2009 at 8:51:17 AM
Page generation time: 3.3880
