Forums >> Revit Building >> Technical Support >> Saving as ???
Wed, Sep 15, 2010 at 9:01:24 PM | Saving as ???
Pele
Pele Avatar
I am learning
I am trying to save a file, Started as a template (.rte) & want to save it as a normal file, a (.prj) I guess, but when I go to save as, the first two options are greyed out, why is this happening why will it not let me do this????
any assistance will be greatly appreciated.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Wed, Sep 15, 2010 at 10:30:23 PM | Saving as ???
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
If you opened an RTE file and started working in it, that is all you can save it as.
See this thread.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=21558
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Wed, Sep 15, 2010 at 11:11:31 PM | Saving as ???
Pele
Pele Avatar
Thx I am working with the Paul Aubin book & have got a reply from him also. He said this.
"Hello Dermot:
Thank you for your email. It sounds to me like you opened the template file instead of creating a new project based on the template file. Do not use the Open command. Use the New > Project command. When you do, you can select a template to use. This will create a new project based on the template. You can then save it as.
Hope that helps.
paul"
I ride a Sportster 1200c
Cheers Dermot
www.dmbd.net
Fri, Sep 17, 2010 at 1:22:07 AM | Saving as ???
Pele
Pele Avatar
thx Brett
Looks like i opened a template instead of a project file & my old AutoCAD habits thought I could then save it as whatever when I wanted
Cheers Dermot
www.dmbd.net
local file saving location [ 1 2 3 ]
Thu, Jul 10, 2008 at 8:03:09 AM
38
saving in previous releases
Wed, Oct 11, 2006 at 3:44:32 PM
Saving to Central
Thu, Mar 12, 2009 at 9:42:05 PM
Saving detail
Mon, Jan 8, 2007 at 10:47:10 AM
Saving New Textures
Thu, Dec 1, 2005 at 6:39:32 PM
Page generation time: 0.0866
