Forums >> Revit Building >> Technical Support >> square cut on shed roof
Wed, Sep 15, 2010 at 4:51:04 PM | square cut on shed roof
geocox3
I have shed roofs on a building and want a square cut on the eaves.  ALL EAVES.  Revit is treating the top eave as if it is half of a ridge, giving me a plumb cut.  How can I get a square cut on both the low and high eaves of a shed roof?
Tue, Jan 11, 2011 at 6:05:16 PM | square cut on shed roof
passell
I can't answer the exact question, but I was able to model roofs with different overhangs at different walls, so you might be able to have other properties differ as well.
Architecturally, Square cuts at the top of a shed are rare because the fascia is more exposed to the weather. Detail carefully to avoid joints where water could run down into the building.
Tue, Jan 11, 2011 at 10:58:05 PM | square cut on shed roof
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Square cut works better when you've used the "overhang" property and picked walls rather than simply drawn the sketch.  I find square cut fails sometimes (dependent on the roof pitch) if you don't do this.
Also, set the fascia dimension to match the roof thickness.
Edited on: Tue, Jan 11, 2011 at 10:58:47 PM
Regards,
Chris.
Tue, Apr 10, 2012 at 10:15:58 AM | square cut on shed roof
jdcarling
Where is the overhang property I cant find it? in Revit arch 2012
Tue, Apr 10, 2012 at 4:21:54 PM | square cut on shed roof
sroreilly
He may mean that when you pick "roof"under the home tab, in the Draw box there is the choice of pick walls (and the overhang amount, define slope tick box, or extend to wall core tickbox shows below the ribbon) or drawing lines with or without offsets.
I have found that odd things happen depending on which way you draw the roof.
Shed roof - top edge square cut? Please Help!
Thu, Oct 11, 2007 at 2:20:27 PM
Can't make a Two Cut - Square rafter cut on a roof
Fri, Jan 14, 2011 at 6:20:30 PM
shed roof with dbl slopes
Wed, Jun 15, 2011 at 8:31:08 AM
Square Cut Rafters
Tue, Nov 20, 2007 at 5:45:45 PM
RAC09 - Roof Fascia Corner Miter on Square Cut
Wed, May 27, 2009 at 6:57:00 PM
Page generation time: 1.5101
