37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Visibility Overwrite Solution?
Wed, Sep 15, 2010 at 10:15:30 AM | Visibility Overwrite Solution?
TeamNga
1 Stars: 1 Votes
Does anyone have a solution to this problem. I am working on something between two existing buildings. I am just about done when my boss asks me to print my plans in color this way.
Existing Building #1 = Blue.
Existing Building #2 = Red
New Construction = Green.
Does anyone know how This could be done?
Thanks.
Wed, Sep 15, 2010 at 10:42:48 AM | Visibility Overwrite Solution?
mercat11
Assuming its temporary drag select the building in a view and > right click> Overide Graphics in View > By element.
Change the various lines and patterns to the colour you want.
Wed, Sep 15, 2010 at 10:47:19 AM | Visibility Overwrite Solution?
Many possible options depending on how you are working.  If the existing buildings were each a phase, you could probably handle it with that.  If they were linked in models, you could handle it through the link.  If the buildings are isolated by workset, you could isolate them in views, select them and over-ride all of the elements.
Wed, Sep 15, 2010 at 12:19:43 PM | Visibility Overwrite Solution?
TeamNga
1 Stars: 1 Votes
Thanks guys. I needed a quick fix. The override graphics in view worked great. But I will definatly look into the phasing when I get a chance.
overwrite label in callout tag
Tue, Jul 3, 2012 at 12:30:50 PM
Paste with Overwrite
Mon, Aug 12, 2013 at 2:40:52 PM
How can I overwrite the object I have uploaded with a new version?
Wed, Sep 23, 2020 at 1:58:56 AM
Visibility of downloaded component
Wed, Jun 5, 2013 at 3:49:42 PM
Type catalog errors
Thu, Jan 19, 2012 at 12:51:36 PM
Page generation time: 0.2229
