Forums >> Revit Building >> Technical Support >> open dome with vertical and horizontal metal bands
Mon, Sep 13, 2010 at 11:31:32 PM | open dome with vertical and horizontal metal bands
Frankjas08
Hello everyone, I am now learning revit architecture 2011 and am having some difficulty on how to go by drawing this open dome. the dome has vertical 4'X12" and horizontal 8"X2" aluminum bands. please see attached images. Thank you for your help it is much appreciated.
Respectfully,
frankjas08
Tue, Sep 14, 2010 at 12:44:08 AM | open dome with vertical and horizontal metal bands
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the Metric or Imperial Library there should be a number of base Mass shapes.  One of which is a dome.
Load and place it on the appropriate level, then using the massing tools place a curtain system by face, swap the panels to empty system panel if you don't require them and place mullions on the grids as required.
Regards,
Chris.
Tue, Sep 14, 2010 at 12:04:00 PM | open dome with vertical and horizontal metal bands
Frankjas08
Thank you Mr. spot, I will draw it up per you directions.
Rendering Images for vertical metal wall panels and standing seam roof?
Wed, Apr 19, 2006 at 9:13:39 AM
Framing along a vertical curve
Thu, Jun 21, 2012 at 1:01:00 PM
Metal Panels for Pre-Engineered buildings
Thu, Dec 16, 2004 at 12:58:45 PM
Vertical and horizontal bracing connections
Mon, Jun 24, 2013 at 7:18:38 AM
How to do a vertical reveal in a sweep in a curved wall?
Thu, Oct 22, 2009 at 2:04:26 PM
Page generation time: 2.0225
