Forums >> Revit Structure >> Technical Support >> beam revit family
Fri, Sep 10, 2010 at 12:33:42 PM | beam revit family
workforlife
Using the wide flange beam family, I created a beam line using Stick Symbols [projection] to show abeam when it is at 0". the problem I have is when the beam is below the view depth the beam line goes away. Is there a way to keep that line from disppearing? I also tried adding the line as a detail component but that doesn't work either.
Creating a beam family
Sun, Apr 17, 2011 at 9:06:00 PM
Shear studs on Steel Beam Family
Wed, Feb 26, 2025 at 5:57:33 AM
Column Family/Beam Family
Fri, Aug 27, 2010 at 1:25:52 PM
Creating a Beam Family
Tue, Sep 4, 2007 at 11:27:05 PM
Creating a Beam Family Where Each Type has a Determined Length
Wed, Aug 31, 2016 at 11:55:27 AM
11
Page generation time: 1.8009
