9 Users Online (8 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Linked Cad File does not show Cad Xref's
Fri, Sep 10, 2010 at 8:23:35 AM | Linked Cad File does not show Cad Xref's
CntrlSwitch
We organize our Cad files by first creating a base floor plan and then xref'ing that plan into a new cad file to add details, notes, callouts ect.  When I try to link the Cad file it only shows the details and not the xref'd plan.  Is there any way to have it show the xref without haveing to explode the cad file so that all elements exist within one file?
Thanks in advance!
Fri, Sep 10, 2010 at 8:34:21 AM | Linked Cad File does not show Cad Xref's
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
It is probably a path issue. You could bind the xref before inserting. I realize that this kind of defeats the purpose of using a "linked" cad file. You could also try to resolve the path issue on the cad files.
Fri, Sep 10, 2010 at 9:05:22 AM | Linked Cad File does not show Cad Xref's
CntrlSwitch
Thanks for the reply.  I'm almost positive the paths are fine, but I'll double check just to make sure.  I guess what I was really trying to determine was that it is possible and I'm not trying to fix something that technically isn't broke.
Fri, Sep 10, 2010 at 10:13:50 AM | Linked Cad File does not show Cad Xref's
TKennedy
4 Stars: 8 Votes
Another thing to check is if the xrefs are set to Attachment or Overlay.
Linked CAD file in Revit won't show XREF
Thu, Jul 25, 2013 at 12:07:29 PM
Linked Cad and reappearing Xref layers
Thu, Dec 4, 2014 at 8:14:32 AM
Linked CAD site plan appears 'crushed' in Revit
Tue, Apr 2, 2013 at 11:00:08 AM
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:14 AM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
Page generation time: 1.9769
