Forums >> Revit Building >> Technical Support >> Interesting Roof - Having Troubles
Thu, Sep 9, 2010 at 11:02:03 PM | Interesting Roof - Having Troubles
Kooray007
I'm using Revit 2011 Arch. trying to put together an interesting roof to top a stair tower (see attached). All I've been able to do so far is build two gable roofs on top of each other. When I join them, the eaves remain on all sides (see drawings - only rakes). I've tried to cut openings using the dormer tool. No luck. Any advice?
 Thanks!
Fri, Sep 10, 2010 at 5:34:11 AM | Interesting Roof - Having Troubles
4 Stars: 205 Votes
You can create that in one piece, "roof by footprint", just draw the shape (square right??) then split those 4 lines in the midlle, then use the "Slope Arrow" where you can give the "slope / height of tail" to those Arrows, you must create 8 slope arrows (2 for each side: ----><-----)
Fri, Sep 10, 2010 at 8:25:10 AM | Interesting Roof - Having Troubles
Kooray007
Typhoon, I'll give it a shot. The other thing I just thought of late last night was joining the geometry and then using two void forms to get rid of the excess "roof". I'll try your method out later today.
Fri, Sep 10, 2010 at 8:32:15 AM | Interesting Roof - Having Troubles
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Typhoon's method is definitely the way to go with this roof. The Void method will work but is a lot more steps.
Fri, Sep 10, 2010 at 9:52:27 AM | Interesting Roof - Having Troubles
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
That's the ticket. Slope arrows but you don't have to split the gable lines.
Leave them as 4 gables and let the slope arrows do the work.
See attached image and project file.
Edited on: Fri, Sep 10, 2010 at 9:54:01 AM
Teaching Revit - How to Make it Interesting
Tue, Oct 6, 2009 at 7:55:48 AM
Hello, new user troubles
Tue, Jul 11, 2023 at 5:59:30 AM
Fire Place Troubles
Thu, Jan 16, 2014 at 7:48:37 AM
work plane troubles
Wed, Jan 25, 2006 at 8:36:53 PM
car and tree families for plan, section and elevation drawings
Sun, Feb 10, 2013 at 10:41:45 AM
Page generation time: 1.9076
