Forums >> Community >> Newbies >> porch stairs
Thu, Sep 9, 2010 at 3:18:54 PM | porch stairs
hermanstreeter
What is the best way to add stairs to a porch or patio?
Thu, Sep 9, 2010 at 3:27:54 PM | porch stairs
Using the Revit stairs.  You don't need a level at the bottom if you are concerned about that... Just set your top and bottom of your stairs off your floor level.
Edited on: Thu, Sep 9, 2010 at 3:28:12 PM
Thu, Sep 9, 2010 at 3:31:10 PM | porch stairs
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Stair starts with riser, and ends with riser and no landing.
I usually make the landing or porch a floor.
Thu, Sep 9, 2010 at 3:38:06 PM | porch stairs
hermanstreeter
Thanks,  what I initially did was make the stairs but since It was all on the 1st level the stairs where just floating, so i added a ground level and that worked.  Was it a more simple way to do that, without adding the level.
Thu, Sep 9, 2010 at 4:20:46 PM | porch stairs
No - you didn't need a level at the bottom - Just a negative offset from your floor.  The top of the stairs might be a negative offset off the floor to if your porch is a step down from the main floor.  I would not have a level for the porch either if it is lower than the floor.  Just have that floor system offset below the main level.
Vynil Porch Post
Fri, Nov 18, 2011 at 8:05:07 AM
screened in porch
Fri, Dec 23, 2005 at 12:21:38 PM
Front Porch Overhang
Sat, Feb 27, 2016 at 11:08:02 AM
Downloaded the Porch of this site, how to insert?
Fri, Nov 30, 2007 at 10:56:57 AM
trying to build custom trim treatment for porch/entry area
Sat, Sep 3, 2016 at 10:26:37 PM
Page generation time: 0.3740
